KellyAB
Nov 01, 2019Tutor
R6700v3 - No Internet light
My power flickered this morning, and my router internet light was amber. I couldn’t get the router to work again so I factory reset it, now the internet light does not come on at all (it’s not amber o...
- Nov 01, 2019I factory reset again and changed out Ethernet cables, had an update to firmware and am now able to use the router again. Thank you for your reply and appreciate you assistance!
Nov 01, 2019Guru - Experienced User
Modem model?
Firmware on router?
The order that i'd start in and move down the steps?
1. reboot your devices in this order after powering both down. Start modem and give it a couple minutes to boot up. Then plug in the router (with nothing else plugged into router) and give it a couple minutes to fully boot. Then log into it and see if you can get the internet settings working.
2. Reinstall the firmware to the router. A factory reset only erases settings. If something was corrupted in the power flicker or the reset, resetting doesn't fix the corruption. A reinstall of firmware is needed. Reinstall the firmware over a hardwired connection, reset the device again, and retry step 1.
3. Still not working? downgrade the firmware 1 version.
here's your support site.
https://www.netgear.com/support/product/R6700V3.aspx
- KellyABNov 01, 2019TutorSo I powered off and on as you directed and the amber internet light cane back on, however the WiFi does not work and I can’t access the app without being connected. How do I update the firmware if I cannot connect?
- KellyABNov 01, 2019TutorI factory reset again and changed out Ethernet cables, had an update to firmware and am now able to use the router again. Thank you for your reply and appreciate you assistance!
