KellyAB
Nov 01, 2019Tutor
R6700v3 - No Internet light
My power flickered this morning, and my router internet light was amber. I couldn’t get the router to work again so I factory reset it, now the internet light does not come on at all (it’s not amber o...
- Nov 01, 2019I factory reset again and changed out Ethernet cables, had an update to firmware and am now able to use the router again. Thank you for your reply and appreciate you assistance!
KellyAB
Nov 01, 2019Tutor
So I powered off and on as you directed and the amber internet light cane back on, however the WiFi does not work and I can’t access the app without being connected. How do I update the firmware if I cannot connect?
KellyAB
Nov 01, 2019Tutor
