nytola77
Mar 25, 2022Guide
R6700v3 and OpenDNS
Question: Can I still configure my router to use OpenDNS servers, specifically the following: Primary DNS: 208.67.222.222 Secondary DNS: 208.67.220.220 Background: I logged into my router and...
michaelkenward
Mar 26, 2022Guru - Experienced User
nytola77 wrote:I just want to use OpenDNS to resolve address lookups.
If you mean that you want to use a different Domain Name Server (DNS) that's nothing to do with OpenDNS.
- nytola77Mar 26, 2022Guide
michaelkenward - Thanks for the reply. I do not want to use the router's "Get Automatically from ISP" setting to specify which DNS server to use. Instead, I want to use 208.67.222.222 as the primary DNS server and 208.67.220.220 as the secondary DNS server, both of which I have read are provided by OpenDNS and both of which are also at the bottom of the OpenDNS web home page Cloud Delivered Enterprise Security by OpenDNS
I just want to make sure, before installing the available Netgear router update, that I will still be able to use the above DNS servers even though one of the router update release notes is "Removed OpenDNS support."
- michaelkenwardMar 26, 2022Guru - Experienced User
Like I said, the setting for the Domain Name Server (DNS) has nothing to do with OpenDNS.
You can easily apply the new firmware update and if you have lost an important setting you can revert to the firmware version you have now.
In any case, whatever you do it would also be a good idea to save a backup of your current configuration. The manual tells you how to do that.
michaelkenward wrote:
"You can easily apply the new firmware update and if you have lost an important setting you can revert to the firmware version you have now.
In any case, whatever you do it would also be a good idea to save a backup of your current configuration. The manual tells you how to do that."
Thanks for confirming that I can revert back to my current firmware version if something goes wrong with the firmware update and for suggesting that I save a backup of my current router configuration.
