bavalpey
Feb 26, 2024Aspirant
R6700v3 blank login page
I am unable to access any part of my router's settings via routerlogin.net.    I am prompted for a password, and when I login it accepts the information. However, the page is just a blank white page ....
- Feb 26, 2024I appreciate your attention to detail. Here is precisely what happened:
 I tried both routerlogin.net and 192.168.1.1. I land on the page using a web browser. I tried opera, chrome, edge, and firefox, all to no avail. I get the prompt for the password login.
 I tried on windows PC, my android phone, and my wife's iphone.When I type it in, it accepts and goes blank. I did try typing it in incorrectly on one of the browsers to see if maybe the screen was just because of an invalid password, but this did cause the username/password prompt to appear again. The factory reset definitely worked, as in, the reset went through. I held the reset button for 30 seconds. It did the disco light mode and rebooted. After all of this, the LED looks as expected. The ssid was reset and everything. I will note that I was able to solve this after much hassle. I figured out how to forcibly install firmware through the command line. I installed an old verison of the firmware and was able to see the login page. I then updated the firmware to the latest version on that page, and it worked. I don't remember the precise firmare version that my r6700v3 was running, but the nighthawk app lied and said it was up to date.
michaelkenward
Feb 26, 2024Guru - Experienced User
bavalpey wrote:
Ok, so I try to reset the modem with a factory reset. Except... This doesn't work.
Doesn't work in what sense? What happens? What are you doing ad where does it go wrong?
When you press the reset button – give it at least 10 seconds – does the router go into "disco light" mode with flashing LEDs as it tries to reboot?
What does the power LED look like after this happens?
- bavalpeyFeb 26, 2024AspirantDoesn't work as in after factory reset, the login page is still blank.- michaelkenwardFeb 26, 2024Guru - Experienced User
 bavalpey wrote:
 Doesn't work as in after factory reset, the login page is still blank.That is the page that you get in a browser? On what? Windows PC? Mac? How did you get there? routerlogin.net? 192.168.1.1? And the other questions? - bavalpeyFeb 26, 2024AspirantI appreciate your attention to detail. Here is precisely what happened:
