barwick11
Apr 10, 2022Tutor
R6700v3 bottlenecking internet speed
We have an R6700v3 that we bought specifically for the internet controls. We've been having issues with our internet but after diagnosing it, it turns out the issues are with the R6700 itself. Any ...
barwick11
Apr 11, 2022Tutor
Firmware V1.0.4.122_10.0.95
Yes I've tried cables. And the same cable from the router to modem was the same cable used from modem to PC (when the PC got 400 mb/s and the router got 80 mb/s)
So, update on the status. Yesterday I did a full factory reset on it, spent hours re-setting up all my settings. I re-run the test, and it's running 400 mb/s after the factory wipe. No clue why this should change anything, or why one should have to factory reset to get full speed from your router, and no clue how long this will last before it requires me to do yet another factory reset, but...
barwick11
Apr 11, 2022Tutor
Who decided this is fixed? I got an email saying I have an accepted solution, come on here and my own answer "solved" the root problem?
Obviously there's something else wrong going on here if RESETTING TO FACTORY is required to get your router to simply do what it's expected to do. I don't think claiming this is solved is exactly accurate... it's a band-aid at best, and if Netgear can get away with thinking this is a viable solution, you get one guess how likely I am to buy their products ever again.
- plemansApr 11, 2022Guru - Experienced User
Is it back to full speed? I can unmark it as solved. But if you're speeds are back, then isn't it resolved?
The problem with the r6700 is it uses ctf to hit gigabit speeds. Its a pretty base model gigabit router and access control, traffic monitoring, parental controls, and qos all disable ctf. And sometimes it takes a full factory reset to get ctf re-enabled.That's why its one of the things we recommend if simply disabling the service and a reboot doesn't fix the issue.
- barwick11Apr 12, 2022Tutor
plemans thanks, that helps understand why it's behaving that way. I didn't know it relied on cut through switching to be able to perform at expected speeds. To be honest I'm somewhat surprised it whacked speeds down to 10% of its rated speed. I do recall almost two years ago running a PC-to-PC connection through the router and getting a bit over 900 Mb/s. I hadn't tried that recently but seeing as prior to the reset it was only getting 85 Mb/s, hence 10% of rated speed.
Honestly, that's really good information for someone to know about, that simple things like QoS, traffic monitoring, access control, and parental controls all disable cut through switching, which slows the router down. Especially considering the fact that I (and others I'm sure) bought this router specifically because it had "advanced" parental controls embedded into the router (ala Circle, which we had previously used the separate device for, but it relied on SSID spoofing).
So unfortunately the router doesn't do what it's advertised to do in the first place now, because not only does parental controls slow the entire router down well below gigabit speeds, but in a separate issue, the parental controls don't even work properly anymore, and haven't for the last 8 months or so. Entirely unknown whether this has to do with the circle software or something Netgear disabled in the router itself, but before and even after the factory reset it doesn't track user's usage history, meaning the time limits we set for the kids don't do anything anymore. But... that's another issue altogether.
Regardless, I can't see a good reason why CTF should slow a router down THIS much, but obviously it was somehow. It would probably be a good idea for Netgear to explain (in the device management interface) that certain functions may slow the router down significantly, and to try disabling them if the router is not performing at expected speeds.
And... well... they should probably find out why CTF doesn't get re-enabled when those functions are turned off, and bug fix it.
- plemansApr 12, 2022Guru - Experienced User
the sad part, is when it was released 8 years ago (2014), the R6700 was a pretty decent performing device. but 8 years in the world of routers/ISP speeds has made a lot of changes. There wasn't many (if at all) ISP's that supplied consumer gigabit speeds. And the processors at that time for routers were a pretty basic arm processor without much power. That's why they needed ctf to hit gigabit speeds. And this wasn't just Netgear. It was all manufacturer's because the limit wasn't software but the hardware they were using. That's why it wasn't an issue for most decent computers to hit gigabit speeds but the routers struggled. You also seen a lot more people building home routers because of how much better performance you'd get at that time.
Fast forward to todays routers/processors and you're getting arm processors that can do active traffic monitoring without much slow down in speeds.
