U_H
Dec 31, 2021Follower
R6700v3 bricked by firmware update?
Dear all, my wifi (R6700v3 as access point) was a bit unstable recently and devices had sometimes problems connecting to it. While having a look at the settings via the browser, I noticed that th...
JeanValjean7
Feb 08, 2022Aspirant
OP stated that their router's power LED would not begin to flash after reboot as stated in Step 10. I am having the exact same issue, power LED goes from solid orange to solid white/blue. Any fix yet here?
Feb 08, 2022Guru - Experienced User
JeanValjean7 usually if its going blue/white, its booted.
Can you ping in on a lan port?
