onlyo
Dec 10, 2020Aspirant
R6700v3 can't open some websites
I have access to internet. But I can't access some websites like: reddit.com, can't login to psn network. Attaching screenshot from Advanced section
Dec 10, 2020Guru - Experienced User
pictures won't show until approved by a moderator. You can click "choose file" and add it that route. then we can see it.
What modem/gateway do you have?
are you using any parental controls?
- plemansDec 10, 2020Guru - Experienced User
R67000 is a router.
What modem/gateway is it connected to?
- onlyoDec 10, 2020Aspirant
plemans, AT&T U-verse Pace 5268AC
The thing is that it is Modem + Wifi. Before Netgear I was using it as Wifi it was loading all websites. Now we turned of wifi function and using it only as a modem, since we got Netgear
Also Netgear was loading reddit.com before. I don't know what happened but it started to give errors now
turning off the wifi doesn't shut off the pace's router functions.
You'd still be in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options? (only use 1)
1. put the pace in passthrough/modem only mode. Can be a bit challenging with this device.
2. put the netgears ip address in the pace's dmz.
3. put the netgear in access point mode. Disables a few features on the router and lets the pace manage them.
