CantonDan
Nov 22, 2022Aspirant
R6700v3 Can't Reset Password or login after firmware update
I just upgraded the R6700v3 to the latest firmware and now I can't login. I am put into a loop asking me to enter a new password. When I try and enter the new password, I receive a message that it'...
michaelkenward
Nov 23, 2022Guru - Experienced User
CantonDan wrote:
I am put into a loop asking me to enter a new password. When I try and enter the new password, I receive a message that it's not meeting the password requirement - even though it does.
Are you sure about that?
Netgear is being a pain by adding ever stronger security features that just get in the way.
How are you trying to access the router? An app or the browser graphical user interface (GUI)?
Wired or wifi?
- CantonDanNov 23, 2022Aspirant
I’m accessing the router via a web browser and I performed the hard reset by using a paper clip and pressing the reset button for 60 seconds. The router is being successfully reset - when the router resets - it puts me into the loop of trying to reset the password. Help!!!!
- michaelkenwardNov 24, 2022Guru - Experienced User
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.I wouldn't usually advise it, but for once, and as an experiment, it might be worth trying to get into the thing with the Nighthawk App.
I say that because Netgear is determined that we should all use that to set up a new router. It may be that they have broken something in the latest update and the GUI won't work. I do hope not.
- CantonDanNov 25, 2022Aspirant
Modem is a netgear CM500 - it’s only a modem and isn’t a combination modem/router.
