Speedyx215
Jan 19, 2021Tutor
(R6700v3) Capped at 200mbps
Let’s make this quick. I pay for 600mbps. In router mode, only get 200mbps on latest update. Downgraded firmware to oldest possible on official website, got 400mbps. Tried using router in AP mode, got...
- Jan 22, 2021
Issue is now FIXED!
Steps used:
- Updated router to latest version
- Factory reset
- unplug router or power off using on/off button
- unplug modem and ethernet cable
- Power on modem while leaving ethernet cable unplugged
- wait for modem to FULLY power back on (For me lights had to be solid)
- Plug ethernet cable back in (And back into router if unlugged)
- Power on router
Previously, I had to "mac spoof" on my router to get connected to the internet(During Netgear genie). After doing this, the issue was gone and now my default gateway is "10.0.0.1" instead of the previous "192.168.1.1". My speed is now what is used to be before I got my own modem (600-700mbps).
Jan 19, 2021Guru - Experienced User
let me know how that goes
Speedyx215
Jan 22, 2021Tutor
Issue is now FIXED!
Steps used:
- Factory reset
- Power on router
