a59cheffy
Apr 18, 2020Aspirant
R6700v3 conected to a CM1100 Modem and a non wifi desktop.....
Heya, I would like to move my non-wifi desktop computer to the other end of my home. I cannot move the network gateway modem/router. (it's Cox, and some of you know what their service is like)....
- Apr 18, 2020
What I am suggesting is an Ethernet connection over power, not same as a wifi extender.
The Ethernet over powerline provides an Ethernet connection at the remote end. You could connect the PC to that and it would appear as an Ethernet connection back to the router. Could also put a switch at the remote end and connect other devices there. As I said earlier, the speed varies by the device. Typically the higher priced the faster.
labatt
Apr 18, 2020Mentor
How about Ethernet over powerline adapter? These typically work well when you cannot run a cable. Has worked well in my house. They are sometimes called powerline network adapters. They very in price primarily because of speed they support.
a59cheffy
Thanks,
I would still have to use a wired connection to whatever device that works. I see the new wifi extenders on Netgear's website. But, I don't see a wired connection for a PC on the back of them.
- labattApr 18, 2020Mentor
- a59cheffyApr 18, 2020Aspirant
Thank you Labatt!
Yes that could work, quite alot of options on Newegg...
