St8103
Oct 19, 2021Aspirant
R6700v3 Constantly Losing Internet
I have a Nighthawk AC1750 R6700v3 that is consistently losing internet access via WiFi at least twice a day. I don't remember exactly when it started but its been at least the past 9 months. I am r...
St8103
I am using spectrum internet via EU2251 modem. Whenever I lose the wifi internet, I am still able to do a speed check via the nighthawk app so the hard wire connectivity exists.
Oct 19, 2021Guru - Experienced User
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 or 149 to 161 channel on 5Ghz.
- St8103Oct 19, 2021Aspirant
No neighbors within wifi range but my 2.4Ghz was set to Auto. 5Ghz is set to channel 153. Also the 2.4 and 5G have separate SSIS's, I am not sure if that is recommended. I read in some places that they should be the same. I will update channels and see if that fixes things
