nicolaira
Jan 28, 2021Initiate
R6700v3 Dropping Signal
My router keeps dropping the WIFI signal a couple of times a day. I'm running on firmware 1.0.4.102_10.0.75 as of 1/28/21 although there's a newer version available. I had to downgrade from that vers...
nicolaira
Hi,
Thanks for the quick reply. I read some other posts and it looks like I may have to revert back to 1.0.3.66 or something, before the Armor got added.
I'll try a manual refresh/reset.
Thanks a bunch. Much love.
Jan 28, 2021Guru - Experienced User
1.0.3.66 is a solid firmware. I haven't been much impressed with the newer armor versions on the 6000-8000 series of routers
