Johnmuledeere
Oct 07, 2021Tutor
R6700V3 email logs thru outlook smtp.office365.com
R6700V3 using V1.0.4.120_10.0.91 firmware, It's making me crazy - what gives with this? When I setup the email log feature, sending the log results in this: "[email failed] STARTTLS is required t...
- Oct 11, 2021
I did that some time ago when we were discussing server IDs and port numbers, looked again this A,M., In my feable way of seeing things MS Outlook (both desktop client and online outlook) settings provide less data than the screen shots I included this morning.
Folks is this hunt worth the effort? I started this out because I wanted to chase some event and thought the log would be a good place to look and since I found the email function in the security tab and the send email in the log page I thought why not? It beats cut and paste.
Well I was wrong, cut and paste is much faster, even if you do need to reformat the output.
So since this dog don't hunt what say we keep the puppy on the porch and find something more interesting to do?
Remember there really are such things as insurmountable oportunities...
Best and Warmest regards to ALL for your valiant efforts.
johnmuledeere
Johnmuledeere
Oct 08, 2021Tutor
Nice try - no cigar. The LB1120 is a cellular only modem. It is set to "Router" mode that according to Netgear disables all ISP intercepts and is a clear pass-through to the R6700V3 WIFI Router. The entire system, end to end has undergone both factory resets and cold starts. The Netgear software and firmware as I indicated are at current levels. I do appreciate your efforts to help resolve this thing. Please keep trying. The original rejection by outlook looks like a simple setting. I just can't find it.
Thanks
Johnmuledeere
Kitsap
Oct 08, 2021Master
Johnmuledeere wrote:Nice try - no cigar. The LB1120 is a cellular only modem. It is set to "Router" mode that according to Netgear disables all ISP intercepts and is a clear pass-through to the R6700V3 WIFI Router. The entire system, end to end has undergone both factory resets and cold starts. The Netgear software and firmware as I indicated are at current levels. I do appreciate your efforts to help resolve this thing. Please keep trying. The original rejection by outlook looks like a simple setting. I just can't find it.
Thanks
Johnmuledeere
Recommend you double check your definition of router mode function. Attached is a snip from the LB1120 manual with a very different definition. If you want to use your R6700V3 Wi-Fi router connected to your cell modem, you need to configure your modem to bridge mode. The most you have to lose in bridge mode is that it does not work. Just where you are now.
- JohnmuledeereOct 09, 2021Tutor
I was wrong. I misunderstood the short description on the 1120 page. I set it as you recommended and as your screen snip documented. Your efforts are appreciated. I changed the 1120 setting, rebooted,and went into the R6700 and reapplied the email settings then went to the logs and sent the log to my email.
Progress!
We now have a different error message, as follows: [email failed] Send hello first [CH0PR13CA0052 .namprd13 .prod .outlook .com], Saturday, Oct 09,2021 07:54:40
any idea what a "hello" is?
You now receive the cigar.
Thanks
Johnmuledeere
- KitsapOct 09, 2021Master
Johnmuledeere wrote:Progress!
The e-mail settings on my R7800 are under Advanced -> Security -> E-mail.
Attached is a snip from the Microsoft Outlook.com web site. Make sure you use the same port number as indicated under SMTP. As a test you should also check the configuration that your e-mail server requires authentication and put in your e-mail user name and password.
- schumakuOct 09, 2021Guru - Experienced User
Beyond of what Kitsap posted, be aware that if you are using 2FA with your Outlook account, a dedicated App Password is required - because of the normal password would trigger a 2FA authentication if the SMTP sender can handle it. https://support.microsoft.com/en-us/account-billing/using-app-passwords-with-apps-that-don-t-support-two-step-verification-5896ed9b-4263-e681-128a-a6f2979a7944
