MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
Chainsawuser
Aug 03, 2021Initiate
I can confirm that R6700v3 with 1.0.4.118 firmware has serious issues.
(just for information, my computer is connected to router via ethernet)
Immediately after installing I got the following errors in Microsoft Edge with every other website I visited.
"Hmmm… can't reach this page
server IP address could not be found."
I checked every single network setting in Windows 10 to make sure nothing had changed (and nothing did).
I checked every router setting and everything was correct.
I did not change one setting on my computer or router because everything was correct.
Went back to 1.0.4.106 and everything is perfect again.
(never had any problems with all the past firmware upgrades, and NEVER had to reset and setup up router again after a firmware upgrade/downgrade)
DragonNest
Aug 04, 2021Aspirant
I just got done hooking up a replacement for the same router I had that i upgraded to the current firmware.
After i upgraded my PC kept on giving no internet errors, wasnt able to access voice chat on xbox app, and even Discord. Kept getting network issues on my gaming consoles.
It was also not showing my connected devices, would say i had 10 connected, but when i clicked on it would only show 1. or 2
I updated though the nighthawk app. Which might up caused the issue, but even after a factory reset it was still happening.
I blame the update on my Nighthawk not even launching on my phone too. The app keeps on crashing on the check network bar. Even after putting in the new router. Though that might be since my phone is kinda old Galaxy s7. Even if it worked before the update.
