MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
Chainsawuser
Aug 03, 2021Initiate
I can confirm that R6700v3 with 1.0.4.118 firmware has serious issues.
(just for information, my computer is connected to router via ethernet)
Immediately after installing I got the following errors in Microsoft Edge with every other website I visited.
"Hmmm… can't reach this page
server IP address could not be found."
I checked every single network setting in Windows 10 to make sure nothing had changed (and nothing did).
I checked every router setting and everything was correct.
I did not change one setting on my computer or router because everything was correct.
Went back to 1.0.4.106 and everything is perfect again.
(never had any problems with all the past firmware upgrades, and NEVER had to reset and setup up router again after a firmware upgrade/downgrade)
snevel
Aug 08, 2021Guide
Same thing happened to me...
Did the upgrade before going to bed and next day my internet was all fscked up.
Unhappily, I spent the best part of 3 hours trying to diagnose the issue (having forgotten about the firmware upgrade as I slept).
I even called my ISP (Cox) for help and they told me a lie (that there was a service outage) just to get me off the phone.
It wasn't until finally plugged the cable modem directly into my desktop (thus bypassing the borked router) that I realized that the router was the problem and I remember the fimware upgrade.
I swung by here, saw that other folk were reporting the same issue and them got the older firmware from netgear and downgraded.
All has been well since.
I've had my router a couple of years and can't get thru on telephone support anymore. Is there any other way to raise this issue with Netgear so they can fix the problem?
