MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
rr98
Aug 10, 2021Initiate
I ran into DNS issue after firmware upgraded. I downloaded the previous version of firmware and downgrade the firmware on my router, that fixed the issue. The link below is the firmware before version 1.0.4.118.
https://www.netgear.com/support/product/R6700v3.aspx#Firmware%20Version%201.0.4.106
delerick
Aug 10, 2021Aspirant
I have the same issue. Since it fixes some bugs and security vulns, I just elected to hard code my various NICs for the time being. But...it is a bug in the newer firmware for sure. Constant DNS lookup fails, timeouts, F5 refresh needed often. THey need to fix this soon.
