MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
snevel
Aug 10, 2021Guide
In reply #14 in this thread (immediately after this post I'm replying to) is a direct link to the firmware file you need to grab.
1 download it
2 you need to unzip it to extract the *.chk file. That's the firmware you need.
3 log into the router's web interface
4 click the advanced tab
5 on the left hand side, under administration, choose router update
6 under "locate and select upgrade file" , browse to the chk file you extracted before
7 click the upload button
8 wait while the router does it's thing (3 or 4 minutes)
9 reboot the router for good luck
You should be good to go.
Good luck!
Simeon
5
1 download it
Good luck!
Simeon
5
