MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
smackmick
Aug 25, 2021Aspirant
Had numerous "Hmm could not find that page", but also missing pictures in Outlook and in Browsers, ftp connection issues. All of these happen immediately on the first connect, then the reload or retry usually fixes them, sometimes it auto reloads. Wish Netgear would acknowledge this, or at least have somewhere to report bugs. Went back to V1.0.4.106 and will see what happens.
118 also has the issue in the router web where the connected devices will not show, shows only about 4 of the 12 or so. Can use the advanced button but this does not show any detail on what the devices are. Going back to 106 fixes this as well.
Not sure I want to advance software again, I hope Netgear says something about fixing these issues.
