MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
eret543
Sep 03, 2021Aspirant
I also have the same issue with my R6700v3 firmware device as this guy mentioned here and still this solution that you guys gave here is not looking suitable to solve it pleasehelp me to solve this issue.
- robjakSep 03, 2021Luminary
What version of R6700v3 firmware are you running?
1.0.4.118 is the problem FW
This would be the fix: https://kb.netgear.com/000062701/R6700v3-Firmware-Version-1-0-4-106
- snevelSep 03, 2021GuideIn what way are the solutions being offered unsuitable?
Until Netgear makes corrected firmware available, the only fix is to rollback to the earlier version
