MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
Sep 23, 2021Guru - Experienced User
Would you please fix the bug in the latest firmware?
this is the community support forum where members of the public help out. We're not netgear. Sometimes a moderator is on here but its a bit rare. But even the mod's can't fix it. It'd have to go to the engineering team
robjak
Sep 23, 2021Luminary
Enginneering has the fix. Hopefully it will be out shortly.
