MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
cochese187
Sep 24, 2021Tutor
This firmware is still 100% broken it the update will cut my bandwidth speeds in half. Everyone I encourage you to do a speed test I have done this off the router and xbox series x and ps5 all with same results. Can someone with the power please tell the devs to fix this. I still have to revert back to older firmware to reach my desired speeds.
