MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
nytola77
Sep 25, 2021Guide
Further to my post #37 above I did the following additional tests:
1. Changed the WiFi frequency from 5.0 Ghz to 2.5 Ghz. Problem persisted.
2. Connected the computer to the router with an ethernet cable. Problem persisted.
3. Connected the computer directly to the modem. The problems were no longer present.
The firmware upgrade to V1.0.4.120_10.0.91 is definitely the source of the problem.
Netgear please fix this.
