MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
Nov 03, 2021Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
jimfacteau
Nov 03, 2021Tutor
Several times
- robjakNov 03, 2021Luminary
go back to the revision of FW before 118. DNS issues started around July 28. Engineering released a beta fix in Sept. They still have not released the official fix. Probably never will.
- jimfacteauNov 03, 2021Tutori would but can't find it on Netgear website
- plemansNov 03, 2021Guru - Experienced User
https://www.netgear.com/support/product/R6700v3.aspx
click on "downloads"
Then click on "+view previous versions"
