MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
R4junC4jun
Nov 10, 2021Guide
Just to reiterate what has been mentioned plenty of times here before. I experienced the same issues on my r6700v3. DNS issues (constant page reloading) and also reduced speeds on a gig connection (reduced to 200-220Mbps). This happened on both 1.0.4.120 and 1.0.4.118...same issues. Downgraded even further as recommended here to 1.0.4.106 to resolve the issues. Make sure you disable your auto firmware update to avoid these "feature updates" that literally kill your router. Disappointing there is still no fix, months after.
- jimfacteauNov 10, 2021TutorExactly, you have to drop to the.... 106 version, this should be a hint to Netgear where to start looking for the problem.
- IndianaBonesNov 25, 2021Aspirant
I've been struggling with this for most of a week. Thought it was my PC until my wife had the same problem. Going back to 1.0.4.106_10.0.80 as I write this, though I got several DNS errors before successfully downloading it, haha!
When I first Googled the issue I learned there are multiple Netgear routers with the exact same issue profile. The same rants, extended timeframes, promised fix announcements, and subsequent multiple broken firmware revisions are repeated - just substitute in a different router model and a different set of fireware numbers in a given Netgear Community thread. I really wonder if they are intentionally breaking old routers so we'll buy new ones.
- jimfacteauNov 25, 2021Tutor
Go back one more version of the firmware, that took care of my problems, it ends in .106
