MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
DarrenM
Nov 29, 2021Sr. NETGEAR Moderator
Please PM me if you would like to try a Trial firmware for the R6400v2 and the R6700v3 that should have fixes for these issues.
Thanks
DarrenM
jimfacteau
Nov 29, 2021Tutor
PM sent also, thank you
