MaxNolder
Aug 03, 2021Tutor
R6700v3 firmware 1.0.4.118 caused connection problems
Thunderbird could not connect to imap servers. SplashTop said no internet. TomTom MyDrive Connect said no internet. Chrome would say site unavailable and then later connect. I went back to previo...
- Sep 24, 2021New 120 Rev appears to be out and fixes the issue, along with others. Running it 5 days now, so far so good.
jimfacteau
Dec 27, 2021Tutor
I did, it took me 3 factory resets to get everything back, then I had to redo all the network names, passwords etc on printers, range extenders etc. In short the entire process sucked and best of all I am still having some website connecting issues with the TLS handshake
R4junC4jun
Dec 27, 2021Guide
Gave the latest R6700v3-V1.0.4.122_10.0.95 a shot just now. Unfortunately I received the same results I did from the .121 trial firmware that I tested from DarrenM. The DNS issues are resolved still, but as soon as I apply the firmware update my internet speeds are reduced in half. 500Mb down to 250Mb. I have again backed out the latest firmware and gone back to version .106 :(
- cochese187Dec 27, 2021TutorYes same here this is the most dumbest thing it cuts my BW in half also. Have to sacrifice security for speed. I thinks it about time to switch to asus for me... Netgear has no ambition to fix these issues at all
- OldDog61Dec 28, 2021Guide
So maybe I got lucky with the new firmware?
I don't believe in luck with tech so maybe it was a combination of things.
I simply installed the driver and waited for the router's Admin logon screen to come back, logged in and verified the install, then rebooted my computer. And I no longer had the DNS issues and my 400/20 Mbps service I pay for is giving me 460/23 Mbps right now (speedtest.net). My MTU isn't dumbed down to 1472 and my boys say their games and minecraft server work fine and without issues.
My computer is a pretty cheap 5 YO computer store custom build:
Windows 10 21H2 (build 19044.1415) 64-bit
AMD A8-6600K APU
8 GB Ram
Chrome browser
I hope those of you with firmware issues are able to get them corrected.
Old Dog
- jimfacteauDec 28, 2021Tutor
as a follow up, I am trying to install the .106 firmware version seeing as this latest one is still an issue. Since the update, resetting and rebooting I can no longer log into Netgear Genie to revert back to the older firmware. The nighthawk app doesn't allow you to revert only go forward on updates. Does anyone have a solution to this problem? Asus is on my horizon!
