AddToCartED
Jan 20, 2021Aspirant
R6700v3 firmware after 1.0.3.66 slows download speeds by a lot.
I have the Nighthawk r6700v3. At firmware version v1.0.3.66 my download speeds are what they should be at which is 450mbps down avg. When I update the firmware to v1.0.4.78 the download speeds are cu...
Jan 21, 2021Guru - Experienced User
When you change firmware, do you factory reset and do a clean install? (not installing from backup)
- AddToCartEDJan 21, 2021Aspirant
I'll give that a shot. I did a factory reset when I acquired the router and did the auto update and noticed the reduced speeds. So I went to the download support site and downloaded all the versions and installed the chk going backwards. But I did not factory reset each time.
