nascarnut
Jul 29, 2021Follower
R6700v3 Firmware Update 1.0.4.118_10.0.90
--- Check for updates --- Gives me the following information but I cannot find any info and/or verify it on Netgear website: (just checking if it's legit and safe to execute the install) --- ...
- Jul 30, 2021Looks like this firmware is OK! Never heard from Netgear, but they posted the release notes to their website: https://kb.netgear.com/000063867/R6700v3-Firmware-Version-1-0-4-118
We probably just stumbled on the update a bit before they intended us to.
Peobody
Aug 06, 2021Guide
I am having the same problem on my R6400v2 router. I there a source from which older firmware versions can be downloaded?
snevel
Aug 06, 2021Guide
Here's the exact link to the downloads for your router:
www.netgear.com/support/product/R6400v2.aspx#download
Under:
Firmware and Software Downloads
expand the "View previous versions" and grab the one you want
