sl21
Jan 21, 2022Follower
R6700v3 Firmware Update Failure
Upon attempting to conduct recommended firmware update through app, after clicking "Check for Updates" tab, getting a "Firmware Check Error" message repeatedly with no ability to bypass. Thoughts?
Jan 21, 2022Guru - Experienced User
You can try manually updating
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
