Rocket45
Dec 17, 2021Guide
R6700v3 Firmware update V1.0.4.122_10.0.95 problem
Attempted update to Firmware ver V1.0.4.122_10.0.95 via Nighthawk iOS (WiFi) app this morning. The update failed in the app and I was prompted to Try Again, which I did. Failed again. Then, went to W...
- Jan 04, 2022
Update: After doing a factory reset on my router, I was able to successfully access the Admin page via PC. Then, after restoring settings via backup from the previous firmware version, I once again lost access to the Admin page on the PC. However, I was able to access the more limited Admin pages via the iOS app (missing such key items as SSID config's, backup/restore settings options, etc.). Internet connectivity was actually fine via PC (wired Ethernet connection) as well as via WiFi devices (able to confirm all devices connected within the iOS app's Admin panel). Even though I was able to access Internet from that point on from all devices, being completely unable to access the full router Admin site from the PC was not going to be acceptable long-term.
I wound up doing another factory reset to the router (which, again, preserved the firmware update itself to ver 1.0.4.122_10.0.95) and then manually restoring all of my settings as best as I could recall from memory (*not* from a previous backup file), making sure to turn OFF the auto-update firmware setting (default setting was to ON) and resolving to never again initiate a router firmware update via the iOS app's Admin panel, as others have also suggested. Since doing this, everything appears to have been working normally in terms of Internet connectivity and access to full Admin page via wired PC, as well as the more-limited Admin panel on iOS app via WiFi.
Although those steps resolved my problem, it is still disappointing that Netgear did not proactively note this was a possibility before proceeding with the upgrade. Also, that it is, apparently, not possible for me to view my earlier backup file's settings in order to confirm that I've correctly set all of my router's settings manually to match the way that I had it configured before.
I would suggest that Netgear disable the ability to update firmware via WiFi app (restricting firmware updates to be initiated from a wired PC only) or, at the least, include a warning that starting an update via WiFi app can lead to inability to access router's Admin page from PC going forward. Also, please set the default setting for auto firmware updates to OFF so that a user must opt-in for auto-updates or manually start update process when convenient for user to do so...
Thanks to all for your suggestions & attempts to help!
Rocket45
michaelkenward
Jan 13, 2022Guru - Experienced User
Committee wrote:
I have a NETGEAR R6700v3 that started power cycling this week.
You have joined in on an existing conversation that may or may not have anything to do with your problems. I see no earlier mention of "power cycling".
The conversation has also been marked "Solved",
So there is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
- JayInTechJan 16, 2022Tutor
You did the right thing buying a different router.
This problem has actually been marked "solved" but it's not. The firmware V1.0.4.122_10.0.95 still breaks access to login on multiple Netgear routers.
The "marked solved" solution states:
"Update: After doing a factory reset on my router, I was able to successfully access the Admin page via PC. Then, after restoring settings via backup from the previous firmware version, I once again lost access to the Admin page on the PC. However, I was able to access the more limited Admin pages via the iOS app (missing such key items as SSID config's, backup/restore settings options, etc.)."
The websever 192.168.x.x is broken in this firmware with no update planned from Netgear.
Rolling back firmware is not something the average user can figure out. The Superuser michaelkenward has shown to be unhelpful and assumes the customer needs to be talked down to, or the customer requires advanced I.T. skills to fix their own product.
By the time someone finds their way in here they've exhausted their at-home resources. You should be grateful users come in here to report and spend their own time fixing Netgear's screwups.
