Eko6
Nov 02, 2021Aspirant
R6700v3 Firmware Version 1.0.4.120
Actualize mi router de forma manual con la versión R6700v3 Firmware Version 1.0.4.120 y al intentar acceder a routerlogin.net 192.168.1.1, 192.168.1.0 router login.com De las diferentes formas que ...
- Nov 02, 2021
Press the back reset button for 10 seconds then release. The try to access the routers web page at 192.168.1.1.
I would turn off any broswser security add-ons while you do this.
Nov 02, 2021Guru - Experienced User
Eko6
Nov 03, 2021Aspirant
Tanks world good.
Reset 10 seconds and disable my firewall and works tank you
- FURRYe38Nov 03, 2021Guru - Experienced User
Enjoy.
