ja2005
Jun 20, 2020Tutor
R6700v3 Firmware Version 1.0.4.92 - Hot Fix
I got the email about the security advisory. I logged into my router and it says that there are no new firmware versions. I have version V1.0.4.84_10.0.58. I logged into my account on Netgear's websi...
- Jun 20, 2020
Hi ja2005,
Welcome to the community! You're almost there! May you proceed starting with step 7 of the article I linked below. Feel free to let me know if you have any questions.https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
Christian
Christian_R
Jun 20, 2020NETGEAR Employee Retired
Hi ja2005,
Christian
- ja2005Jun 20, 2020Tutor
Hi Christian,
Thank you for your response. I have a stupid question. The file saved as this: R6700v3-V1.0.4.92_10.0.67_Beta and the type is Compressed (zipped) Folder. When I select that after clicking on Browse from your instructions, and click Upload, it says Please assign the correct file. The file format is *.chk Do you know what I did wrong or do I need to do something to the compressed folder before trying to upload?
Hi Christian,
Please ignore that last question (stupid question), I think I figured it out! Thanks again!
- antinodeJun 20, 2020Guru
> [...] I think I figured it out! [...]
Not much detail there.
> 8. Unzip the file if needed.
Lame instructions. More helpful might be something like, say:
8. Extract the firmware image (".chk" or ".img") and Release
Notes (".html") files from the ".zip" archive, if necessary.
(Some web browsers do this automatically.)More detailed instructions on how to do that wouldn't hurt, either.
