aschanick
Apr 06, 2020Initiate
R6700v3 internet connection Issue - can't set up
I have been using my R6700v3 router with a Netgear CM400 modem with no issues. Today, I switched to the Arris SB8200 and now my router will not connect to the internet (internet LED is blinking amber...
- Apr 06, 2020
Thank you for your replies. In the late hours of the night last night, I actually stumbled on the fix myself. I "forgot" the wifi network associated with my router on my PC, then 1) powered down PC, modem, router, 2) plug in modem, wait for full boot, 3) plug in router and wait for it connect, and 4) set up router using nighthawk app, and that fixed the issue somehow. This was after many attempts at power cycling both the modem and router, but it was the first time I had included my PC in the power cycle. I don't know what part of this could have fixed the issue, or if it was something unrelated - just wanted to share what happened in case this might work for someone else having this same issue.
Thanks!
additude
Apr 06, 2020Virtuoso
In the routers "Internet Settings" does the router have a WAN IP address / Gateway and DNS ?
