smackmick
Jun 22, 2022Aspirant
R6700V3 latest update 1.0.4.126
It has been a while since I visited the updates. The R6700V3 had a lot of issues with 1.0.4.122, and most people were going back to 106. Has anyone used 126 and had good results? I am a little rel...
michaelkenward
Jun 23, 2022Guru - Experienced User
smackmick wrote:
I am a little reluctant to update but there has been a lot of security updates I should get.
Search - NETGEAR Communities – R6700V3 firmware
You can always roll back if new firmware causes problems.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
- justanguser2Jul 02, 2022Tutor
I took this router out of closet and upgraded to R6700v3-V1.0.4.126_10.0.102, gave it away to my daughter to use. Initial testing seemed ok - as others had mentioned -- no mysterious DNS ERR connection drops ... but time will tell.
