imza6666
Dec 02, 2019Guide
R6700v3 loses internet daily
Every morning when I wake up, my router has wifi but no internet, and must be restarted. Ethernet has no problems, it's only wifi. Restarting the router solves the issue. I saw in another thread that...
- Dec 02, 2019
The R6700v3 recieved netgear armor about 2'ish version ago via firmware update. I've noticed many people have issues after this update.
some are solved by a simple factory reset. Some require downgrading the firmware to the version prior to armor. I'd start with a factory refresh and a manual reinstall/setup (avoid backup configuration if you have one). If this doesn't fix the issue, then I'd try downgrading the firmware to version 1.0.3.66. Make sure to do it over a hardwired connection and to reset the router afterwards. I'd also disable auto updates.
let me know how it goes.
Dec 02, 2019Guru - Experienced User
What firmware are you on?
Modem you're connect to?
Is it both wifi channels or isolated to 2.4/5ghz?
There is a wireless schedule. Possibly you have that setup? Page 70 of the manual walks you through wireless schedule.
https://www.netgear.com/support/product/R6700V3
- imza6666Dec 02, 2019Guide
-latest firmware
-modem is TM1602A MTA - has no issues, as ethernet works fine
-both wifi channels, I believe it's both but I know for sure 5g is affected
-no scheduled items in router settings
- plemansDec 02, 2019Guru - Experienced User
