imza6666
Dec 02, 2019Guide
R6700v3 loses internet daily
Every morning when I wake up, my router has wifi but no internet, and must be restarted. Ethernet has no problems, it's only wifi. Restarting the router solves the issue. I saw in another thread that...
- Dec 02, 2019
The R6700v3 recieved netgear armor about 2'ish version ago via firmware update. I've noticed many people have issues after this update.
some are solved by a simple factory reset. Some require downgrading the firmware to the version prior to armor. I'd start with a factory refresh and a manual reinstall/setup (avoid backup configuration if you have one). If this doesn't fix the issue, then I'd try downgrading the firmware to version 1.0.3.66. Make sure to do it over a hardwired connection and to reset the router afterwards. I'd also disable auto updates.
let me know how it goes.
Dec 02, 2019Guru - Experienced User
What firmware are you on?
Modem you're connect to?
Is it both wifi channels or isolated to 2.4/5ghz?
There is a wireless schedule. Possibly you have that setup? Page 70 of the manual walks you through wireless schedule.
https://www.netgear.com/support/product/R6700V3
imza6666
Dec 02, 2019Guide
-latest firmware
-modem is TM1602A MTA - has no issues, as ethernet works fine
-both wifi channels, I believe it's both but I know for sure 5g is affected
-no scheduled items in router settings
- plemansDec 02, 2019Guru - Experienced User
- imza6666Dec 10, 2019Guide
plemans wrote:The R6700v3 recieved netgear armor about 2'ish version ago via firmware update. I've noticed many people have issues after this update.
I disabled Netgear Armor and the problem was solved. Thank you very much.
- plemansDec 10, 2019Guru - Experienced User
Glad to hear you got it fixed. Not as excited about armor causing the issues. I've been seeing more of this on the forums as its rolled out to older routers.
