imza6666's avatar
Dec 02, 2019
R6700v3 loses internet daily
Every morning when I wake up, my router has wifi but no internet, and must be restarted. Ethernet has no problems, it's only wifi. Restarting the router solves the issue. I saw in another thread that...
  • plemans's avatar
    Dec 02, 2019
    The R6700v3 recieved netgear armor about 2'ish version ago via firmware update. I've noticed many people have issues after this update.
    some are solved by a simple factory reset. Some require downgrading the firmware to the version prior to armor. I'd start with a factory refresh and a manual reinstall/setup (avoid backup configuration if you have one).  If this doesn't fix the issue, then I'd try downgrading the firmware to version 1.0.3.66. Make sure to do it over a hardwired connection and to reset the router afterwards. I'd also disable auto updates.
    let me know how it goes.
