Guy77's avatar
Guy77
R6700v3 networks not showing
Hi. Have a R6700v3 that is 12 days out of warranty and is with my daughter away at school.  Issue is that neither of the 2.4GHz or 5GHz networks are showing as being able to connect to from any dev...
  • michaelkenward's avatar
    Sep 04, 2021
    Guy77 wrote:
    -Only the first 2 lights are lit (Power & Connection)
    This might be hard to believe, but it sounds like you may have switched off the wifi.
    I say hard to believe because it is far from obvious that the wifi LED on the top of the router is also a switch. That's why a lot of people turn up here with the symptoms you describe. Cats and children have been known to throw that switch.
    Look at the WiFi On/Off button on the top. Press it. Any luck?
    The switch overrides the browser graphical user interface. So you can't switch it back on from there.
