Benthebot
Jul 18, 2019Initiate
R6700v3 New Firmware Slow Speeds
Hi. I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was...
knarlomatic
Jan 19, 2020Tutor
Must echo all the other replies here. It seemed that lately my speeds on my r6700v3 had gone from 100/10 to 15/.5 and 4x my regular pings. I tried restarting all the equipment from the pcs to the router to the cable modem, no change. Plugged my laptop into the modem, and got the advertised speeds. I found this thread and using others for some instructions downgraded firmware from 1.0.4.84 to 1.0.3.66. I forgot to do the factory reset (with the reset button in back) and got confused that I now had 100/.5 with the same bad pings. Finally realized:
******DON'T IGNORE THE POSTS THAT SAY DO A FACTORY RESET!******
After the flash of the 1.0.3.66 firmware and factory reset all speeds through the router from any device are now as advertised!
Unfortunate that we have to use an insecure version of firmware, and spend half a day troubleshooting.
Has anyone tried the DDWRT builds? Does it solve these problems and how is the experience?
I saw that one message on these forums about the R7000 had the same issue and one of the posters noted that he just did a factory reset (without changing firmware) and it worked for him. Anyone else try this? It would make sense, maybe after the newest build was installed all we needed to do was a factory reset. Again, if true, it's unfortunate that no one told us, and that all your settings need to be reentered.
- knarlomaticApr 06, 2020Tutor
I recently noticed the issues cropped back up again. Looked in the firmware and found that somehow the firmware had been upgraded after I turned off that option. Decided to try a factory reset and darned if that didn't fix the problem. All systems normal.
- A_ALIApr 06, 2020Star
What is the Firmware version after the factory reset? What was your previous version?
- knarlomaticJun 14, 2020Tutor
new 1.0.4.84 old 1.0.3.66
