Benthebot
Jul 18, 2019Initiate
R6700v3 New Firmware Slow Speeds
Hi. I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was...
Plothary
Feb 07, 2020Initiate
I had the dance problem as everyone in these threads... Pitiful speeds - 20mbps on a spectrum 2000mbps plan - and finally tested flashinh DD-WRT onto the router.... INSTANT FIX. This works. It's as if the OEM firmware is preloaded with a rootkit! WRT is the fix.
- Retired_MemberFeb 07, 2020
Would you please provide step by step instructions to accomplish this? I have litterally tried everything with no success
- A_ALIFeb 08, 2020Star
Please provide instructions for the update!!!
Thank you!!
- dp_Feb 08, 2020InitiateReview these steps, should be similar but can’t guarantee:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router - PlotharyFeb 14, 2020Initiate
