Benthebot
Jul 18, 2019Initiate
R6700v3 New Firmware Slow Speeds
Hi. I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was...
knarlomatic
Apr 06, 2020Tutor
I recently noticed the issues cropped back up again. Looked in the firmware and found that somehow the firmware had been upgraded after I turned off that option. Decided to try a factory reset and darned if that didn't fix the problem. All systems normal.
A_ALI
Apr 06, 2020Star
What is the Firmware version after the factory reset? What was your previous version?
- knarlomaticJun 14, 2020Tutor
new 1.0.4.84 old 1.0.3.66
