Benthebot
Jul 18, 2019Initiate
R6700v3 New Firmware Slow Speeds
Hi. I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was...
A_ALI
Nov 11, 2019Star
I just wanted to add to this conversation. Purchased the V3 version of this router a few months ago at the same time that I upgraded my internet speeds with Comcast to 1GB. I was only getting top out speeds of 250GB. Verified that I was getting 1GB over the wire with comcast, had them check wiring and cable to the house. All verified correct. I directly connected my desktop to the cable modem (Netgear CM1000), removing the router all together, and my speeds shot up to 989GB! Found a couple of articles on the forums here, and after troubleshooting here over a few days, I was finally able to achive very close to my advertised speeds with the router by downgrading to V1.0.2.66_10.0.48 firmware. Turned off auto updates, and have never looked back.
I do check occasionally to see if there is a newer FIXED version of the firmware, but I find that Netgear simply doesnt care at this point. They are concentrating on their newer products. I get that, but to resolve this issue should at least be on the radar! I dont want to have to spend $300-$400 on a new router when I have one that fits my needs, and doesn't look like an eyesore sitting in my living room. Not having the latest firmware does not give me the best feeling, but if that is what I have to do to keep my 18+ devices in my house working so be it. When this router dies, I'll upgrade. Until then...Old firmware it is!!
Gammafist
Nov 21, 2020Aspirant
Just curious did you test out 1.0.3.66 firmware before deciding on your current firmware?
- RailheadNov 21, 2020TutorI could not afford the week of down time attempting to reach or discuss the matter with Netgear’s so-called “Tech Support”.
I am going to leap-from several firmware versions to the current release this weekend, and immediately check the speeds on all connected devices.- Retired_MemberNov 21, 2020I’m running the latest firmware (V1.0.4.102_10.0.75) with GB internet and no issues. Highly recommend a full factory reset regardless of whichever version your choose.
- A_ALINov 21, 2020StarI'll try again this weekend as well. I recently did a factory reset and had speeds that were acceptable for about 3-4 days, then tanked again. Will report back Sunday.
