Benthebot
Jul 18, 2019Initiate
R6700v3 New Firmware Slow Speeds
Hi. I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was...
FTurpin
Apr 30, 2021Aspirant
Is there and update to this information? I have the same problem. The firmware was updated and can not get the 300mbs that I have contracted with my ISP. I try down grading the FW to the version mentioned on the original post but did not work.
Any help is appreciate it.
Benthebot wrote:Hi.
I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was only getting download speeds of about 150Mbps. I tested several times over a few days and the speeds were staying the same. I plugged my computer directly into my modem and I started getting above 300 again, so it seemed the problem was with my router. I tried rebooting and factory resetting my router a couple times, but that didn't help (both on factory settings and after making changes). I found another forum thread (https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7000-Slow-Internet-Speed-Our-Fix-SOLVED/m-p/1483216) about an R7000 with similar problems. I skimmed through it and saw that he fixed his problem by rolling back a firmware version, so I gave that a shot.
I noticed my router had firmware auto updates turned on and version 1.0.4.78 installed. I downloaded version 1.0.3.66 and flashed the firmware through the web interface. I immediately started getting speeds over 300Mbps again (both on factory settings and after making changes). I upgraded the firmware back to the newest version, and the speeds dropped again. I downgraded it to 1.0.3.66 again, and it was fixed again.
So now I'm using 1.0.3.66 and turned off firmware auto updates. I couldn't find others with this same issue on the same model, but I thought it should be reported somewhere. Let me know if there is a better place to report (seems like I couldn't contact Netgear support without paying for premium support).
Thanks,
-Ben
- OriginalSavageApr 30, 2021Aspirant
Make sure you turn off auto update first, then downgrade the firmware.
I don't know whether or not Netgear thinks there's a problem or not. I'm staying on the old firmware.
- Retired_MemberMay 03, 2021
I've had so many problems with this router since purchasing - although I will say the newer firmware versions have resolved my down speeds. A few things that have worked to get back to just under 1gb AT&T speeds (hardwired):
- Factory resetting router (don't restore backup settings from a file) then manually change your individual settings
- Cut power to the router completely for ~5 min
- I've noticed Windows will want to use wifi during times when you are restarting the router repeadily so disable wifi when running speed tests or restart your PC
- Disable/unplug other devices on your network for best accuracy
Finally be aware if you are speed testing using wifi the best you can hope for is 300-400 down (in my case I have 1gb internet) even under the best of circumstances. You mentioned you have 300 mbps plan - I'd be surprised if you hit those speeds anytime other than 2-3am (when the network is least congested). With my 1gb internet I generally hit 700-800 down hardwired.
- OriginalSavageMay 04, 2021Aspirant
Retired_Member wrote:I've had so many problems with this router since purchasing - although I will say the newer firmware versions have resolved my down speeds. A few things that have worked to get back to just under 1gb AT&T speeds (hardwired):
Are you saying you encountered the issue with firmware updates after V1.0.3.66_10.0.50, but the latest update solved that problem or at least, solved it after the steps you listed below? I'd like to stay current but not when it breaks functionality.
- FTurpinMay 04, 2021Aspirant
Thank you for your help!!! I did troubleshooting with NETGEAR and they determined as I did before the call that the router was defective the 5mhz radio is not working so I will be getting a new one. Hopefully it will work fine right out of the box.
Cheers.
