Benthebot
Jul 18, 2019Initiate
R6700v3 New Firmware Slow Speeds
Hi. I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was...
FTurpin
Apr 30, 2021Aspirant
Is there and update to this information? I have the same problem. The firmware was updated and can not get the 300mbs that I have contracted with my ISP. I try down grading the FW to the version mentioned on the original post but did not work.
Any help is appreciate it.
Benthebot wrote:Hi.
I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was only getting download speeds of about 150Mbps. I tested several times over a few days and the speeds were staying the same. I plugged my computer directly into my modem and I started getting above 300 again, so it seemed the problem was with my router. I tried rebooting and factory resetting my router a couple times, but that didn't help (both on factory settings and after making changes). I found another forum thread (https://community.netgear.com/t5/Nighthawk-WiFi-Routers/Netgear-R7000-Slow-Internet-Speed-Our-Fix-SOLVED/m-p/1483216) about an R7000 with similar problems. I skimmed through it and saw that he fixed his problem by rolling back a firmware version, so I gave that a shot.
I noticed my router had firmware auto updates turned on and version 1.0.4.78 installed. I downloaded version 1.0.3.66 and flashed the firmware through the web interface. I immediately started getting speeds over 300Mbps again (both on factory settings and after making changes). I upgraded the firmware back to the newest version, and the speeds dropped again. I downgraded it to 1.0.3.66 again, and it was fixed again.
So now I'm using 1.0.3.66 and turned off firmware auto updates. I couldn't find others with this same issue on the same model, but I thought it should be reported somewhere. Let me know if there is a better place to report (seems like I couldn't contact Netgear support without paying for premium support).
Thanks,
-Ben
OriginalSavage
Make sure you turn off auto update first, then downgrade the firmware.
I don't know whether or not Netgear thinks there's a problem or not. I'm staying on the old firmware.
