Benthebot
Jul 18, 2019Initiate
R6700v3 New Firmware Slow Speeds
Hi. I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was...
Anonymous
May 03, 2021I've had so many problems with this router since purchasing - although I will say the newer firmware versions have resolved my down speeds. A few things that have worked to get back to just under 1gb AT&T speeds (hardwired):
- Factory resetting router (don't restore backup settings from a file) then manually change your individual settings
- Cut power to the router completely for ~5 min
- I've noticed Windows will want to use wifi during times when you are restarting the router repeadily so disable wifi when running speed tests or restart your PC
- Disable/unplug other devices on your network for best accuracy
Finally be aware if you are speed testing using wifi the best you can hope for is 300-400 down (in my case I have 1gb internet) even under the best of circumstances. You mentioned you have 300 mbps plan - I'd be surprised if you hit those speeds anytime other than 2-3am (when the network is least congested). With my 1gb internet I generally hit 700-800 down hardwired.
OriginalSavage
May 04, 2021Aspirant
Retired_Member wrote:I've had so many problems with this router since purchasing - although I will say the newer firmware versions have resolved my down speeds. A few things that have worked to get back to just under 1gb AT&T speeds (hardwired):
Are you saying you encountered the issue with firmware updates after V1.0.3.66_10.0.50, but the latest update solved that problem or at least, solved it after the steps you listed below? I'd like to stay current but not when it breaks functionality.
- FTurpinMay 04, 2021Aspirant
Thank you for your help!!! I did troubleshooting with NETGEAR and they determined as I did before the call that the router was defective the 5mhz radio is not working so I will be getting a new one. Hopefully it will work fine right out of the box.
Cheers.
- AnonymousMay 05, 2021
I'm using V1.0.4.106_10.0.80 and getting full speeds. Another item I failed to mention before is making sure to disable Access Control functionality - I've noticed this cuts the speed on mine as well.
