Benthebot
Jul 18, 2019Initiate
R6700v3 New Firmware Slow Speeds
Hi. I have a Netgear 6700v3 connected to a Netgear CM600 modem. I pay for 300Mbps download and 30Mbps upload. I usually get 300-340Mbps download during speed tests. I noticed recently that I was...
EBicker
Nov 17, 2021Aspirant
I have a Nighthawk R6700v3 with the latest firmware (v1.0.4.120) installed and recently noticed that I was having the same speed issue. It turns out that I had turned on Traffic Meter in the app a couple days ago. Turning it off immediately increased download speeds from 200Mbs to 700Mbs without rebooting.
- Retired_MemberNov 17, 2021
Agreed! I noticed keeping the access control functionality disabled as well keeps the speeds as expected.
- mattfinley12Jan 12, 2022Aspirant
Not to bump an old thread, ran into the same problem as everyone else... I forgot to turn of auto update and got lousy speeds after not noticing it for a while... rolled back to 1.0.3.66_10.0.50 and everything is good. I mean WTF... you have to roll back to a 2 year old version to get proper speeds?
- FURRYe38Jan 13, 2022Guru - Experienced User
Did you disable Access Controls and Traffic Meter after doing a factory reset on current version of FW?
