bsa79
Aug 29, 2022Aspirant
R6700v3 No WebGui and no App after update
Hi all, after the latest update of the router, I have no access to the GUI any longer (not using the static IP, not using www.routerlogin.net, not HTTP, not HTTPS, not in Safari, not in Chrome, n...
michaelkenward
Aug 29, 2022Guru - Experienced User
bsa79 wrote:
Any suggestion how to get that thing into a fully working state again?
It is a pain, but a reset is the first thing to try after an update has wrecked your router.
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
With luck you will have a configuration backup that you can reload.
bsa79
And... with bad luck I have a R6700v3 that doesn't do anything anymore... I guess?
So, let's assume I end up in that situation, what's next then?
- KitsapAug 29, 2022Master
No need to jump to conclusions and borrow trouble.....
After a firmware default reset or maybe two, you should be able to configure your router from scratch.
If not, there are ways to upload firmware to the router. See below.
- bsa79Aug 29, 2022Aspirant
Thanks to you, too. I tried the Mac guide earlier today and it did not do anything.
My devices PowerLED doesn't flash at all, so I tried different times, when it lights up after powering the device.... I am not sure if the 192.168.0.10 is supposed to be an example or if the router actually picks this IP during the boot phase...
Kind regards,
Sascha
When you had your original firmware update failure, how were you connected to the router? With a phone, computer? Via Wi-Fi or Ethernet cable?
- michaelkenwardAug 29, 2022Guru - Experienced User
Who knows. Dig deeper?
Take this:
The error I get is: ERR_EMPTY_RESPONSEA quick search suggests that this is not a Netgear issue.
ERR_EMPTY_RESPONSE - Google Search
More locally:
Search - NETGEAR Communities – ERR_EMPTY_RESPONSE
More of a network issue.
Did you try either of those?
