bsa79
Aug 29, 2022Aspirant
R6700v3 No WebGui and no App after update
Hi all, after the latest update of the router, I have no access to the GUI any longer (not using the static IP, not using www.routerlogin.net, not HTTP, not HTTPS, not in Safari, not in Chrome, n...
bsa79
And... with bad luck I have a R6700v3 that doesn't do anything anymore... I guess?
So, let's assume I end up in that situation, what's next then?
Kitsap
Aug 29, 2022Master
No need to jump to conclusions and borrow trouble.....
After a firmware default reset or maybe two, you should be able to configure your router from scratch.
If not, there are ways to upload firmware to the router. See below.
- bsa79Aug 29, 2022Aspirant
Thanks to you, too. I tried the Mac guide earlier today and it did not do anything.
My devices PowerLED doesn't flash at all, so I tried different times, when it lights up after powering the device.... I am not sure if the 192.168.0.10 is supposed to be an example or if the router actually picks this IP during the boot phase...
Kind regards,
Sascha
- KitsapAug 29, 2022Master
When you had your original firmware update failure, how were you connected to the router? With a phone, computer? Via Wi-Fi or Ethernet cable?
