Holmis
Oct 11, 2023Guide
R6700v3 OpenVPN not working
Can not get OpenVPN to work... I have followed the instructions below. see attached log file... something about "TLS error: Unsupported protocol."?? log Regards Holmis
abdsea
Oct 29, 2023Guide
The issue is due to server TLS level is 1.0 and it is considered insecure. OpenVPN client calls it insecure mode.
Go to settings -> advanced settings -> choose "Insecure" and then retry connection. We will not be able to do much without netgear providing a firmware update to switch OpenVPN server settings to use TLS 1.3 or above.
Changing UI settings will not solve the problem as suggested by prior post.
- HolmisNov 05, 2023Guide
Thank for the answer, but is it in the OpenVPN client I need to change or in the router?
I cant find any "Insecure" setting in my client or do you recommend a version of the client?
I use OpenVPN GUI or is there another better OpenVPN client?
regards
Stefan Holmgren
Ok... downloaded "OpenVPN Connect" and found the advanced setting...
but now I cant import the profile?!?...
- KitsapNov 05, 2023Master
Holmis wrote:Ok... downloaded "OpenVPN Connect" and found the advanced setting...
Repeat question: What type of device are you running the client application on? Android, Windows, ??
I cannot see an inserted image until a moderator approves it. If you attach an image, I can see it as soon as it is posted.
