Holmis
Oct 11, 2023Guide
R6700v3 OpenVPN not working
Can not get OpenVPN to work... I have followed the instructions below. see attached log file... something about "TLS error: Unsupported protocol."?? log Regards Holmis
abdsea
Nov 07, 2023Guide
hi Stefan,
your profile looks good, apologies for missing it earlier. TAP mode is not supported on OpenVPN 3, i missed the TAP message from your screenshot. Try using the 2.x client from the download page https://openvpn.net/client/client-connect-vpn-for-windows/
thanks
abdsea
Nov 07, 2023Guide
or the community download https://openvpn.net/community-downloads/
- HolmisNov 07, 2023Guide
Thanks a lot for helping me, but with this version I'm back where I started, my first post...
hmm... maybe you can find something in the log file, attached it as a pdf... (I removed domain name)
- abdseaNov 07, 2023Guide
did you change the insecure mode, if the option available?
second, you could try adding this in a new line "tlsversion-min 1.0" in your profile based on this error message
"If your OpenVPN client is between v2.3.6 and v2.3.2 try adding tlsversion-min 1.0 to the client configuration to use TLS 1.0+ instead of TLS 1.0 only "
yes added "tls-version-min 1.0" to my profile, but still same error...
maybe I need an older version of OpenVPN GUI??... installed OpenVPN-2.6.6-I001-amd64
Regards
Holmis
Now its working... downloaded an older version of OpenVPN... openvpn-install-2.4.6-I602
Regards
Holmis
- abdseaNov 08, 2023Guide
Glad you found the right client version, it should be simpler but an arduous effort 😂🤣
